cazzy93
Air Filter
cazzy93
i have a xs engine in my 205xe shell and do not have the standard air filter box or pipes, at the moment i am running a bit of foam cable tied over the carb, i did have a piper cross foam filter that screwed onto the top of the carb with a jubliee clip but this fell apart, what sort of filter could i use i also have a strutbrace that is close to the top of the carb so this will restrict what type of air filter i can use. can you still buy the red piperx foam air filters or not??
cheers
RyszW
cheers
Would it be worth fabbing your own intake 'tube' and bolt on a cone filter to the end of it if space is at a premium as you could then route the filter to a convenient part of the engine bay and ghetto drainpipe tube would do the job I would imagine as long as you route it away from the exhaust headers!
Rysz.
