[body_work] Sill Repair
Thought I'd put up a few pics of a bit of work I'm on with at the moment.
The car in question is in the main a very very original 1988 1.9 non sunroof GTI. It was bought between me and a mate a while ago with the intention of stripping it for parts but to be honest it seemed a shame to do so to such a nice original car.
Therefore slowly around other projects it has gradually been brought back to top spec mechanically, it had suffered all the usual well used 205 traits, such as knackered driveshafts and wheel bearings, collapsed rear beam, snapped off rear caliper bleed nipples etc etc.
The last bit of work needed before it gets a darn good polish and we decide what to do with it was some bodywork repair. The only bit of bodywork that wasn't good on the car was the drivers side seam between the sill and the rear quarter.
It looked as though the sealant had failed and this had let water in causing rust, but when I took a good look at the area, it was evident that the sill had been scraped along a low post or stone, this has caused the very rear edge to be bare metal, and water had got under the sealant there.
After a good going over with the wire brush on the angle grinder this is what I found, not at all as bad as it looked beforehand TBH.
However as I delved further I found that the return on the end of the panel had basically disintergrated, and there was a small rotten patch where the scrape to the sill would have been at its worst. Not wanting to do half a job I set about bare metalling it, and then with the air saw cut out a square, and made a neat patch to butt weld into place.
Once I'd welded that into place and linished off the welds I made up a new return to go on the rear edge into the wheelarch. This was then welded on, and then the welds were linished back to copy the original radius that exists between the quarter panel and the return. I was quite pleased with how this turned out.
Next job was to spend some time getting the crap out of the join between the sill and quarter, and then treating it with Loctite rust inhibitor stuff. Once this had been done I got stuck in with the Wurth seam sealer and sealed the join as well as I could to copy the factory sealer. There were also some tiny "spiders legs" running beneath the lower part of the quarter panel so this was flatted back with the DA ready for paint.
Once the sealer had cured it was out with the stonechip to do as best a job as I could at recreating the factory finish to the sills. The stuff in an aerosol can is useless, so I use Gravitex applied with a underbody Shultz type gun. It comes in white grey and black so I chose white, it will also be overpainted when I paint the lower part of that quarter panel.
So here is where I am up to so far
More to come.
looks great there Tom, are you doing any repairs to the 1/4 panel above the sill?
I need to find out how one would go about repairing a hole in the 1/4 panel just above the patch you've done on the sill.
No, aside from some rust converter it doesn't need anything doing to it.
To repair a hole in the 1/4 panel you'd have to cut out and butt weld a piece in, in exactly the same way as I've done on the sill.
paul205mi16
Good job there Tom.
Remembered I never posted to finish this off.
When prepped the lower half of the quarter was primed
And then later topcoated. Once hardened off it was polished back, the finished job looks like this
Not a bad job, I'm happy enough with it.
Ethos
Want to come down and do mine? ;)
Very good job there mate!!!
dale205mills
That look's great and well done for shareing it with fellow 205 people ;)
Cheers chaps, I am of course available for similar repairs to other peoples cars on request.... B)
Dan Ingram
Do all 205 GTis have that finish on the sill? My car has been painted at some point so I don't know if its the correct finish or not. Its just the same finish as the rest of the car. I have to do a similar repair on my car so I may as well have it right.
As far as I know they do, yes.
Hardgraf
Good job mate. How much would you expect a bodyshop to charge for this as both my sills are similar?
Sorry buddy I've no idea, I've never used a bodyshop for anything (do it myself).
Dan Ingram
I got a quote to have the sill repaired and the whole side sprayed so it matches and it was £300. Thats from a local body shop with a very good reputation.
Hardgraf
It would be great if you could sort out my sills but I'm in Bristol so It's a massive mission to Rotherham!
JimLad
Great work there! Wish I wasn't so useless when it comes to bodywork.
Hardgraf, it's not that bad a trek if you get up early and I'm sure you'd get an excellent job at a good price! I'll certainly bear Tom in mind if I need any bodywork :lol:
Alastairh
Great work mate ;)
Ethos
Wish you lived closer, I'd happily pay good money for this level of correction!
Smudgey1985
Top job!!! Got the joy of starting the quarters on mine this week!!
