All Praise The GTI
8v Turbo Water Works
All Praise The GTI
i searched to try find a diagram but no luck, anyone help?
thanks
saveloy
There are 2 rubber water pipes that go into the bulkhead behind the turbo, and feed the heater matrix. Use the top one straight into the turbo and the return feeds the standard pipework, beneath the turbo and at the bottom of the block.
Don't use the std rubber hoses, obviously. Use silicone.
All Praise The GTI
i think i know what you mean but i hadnt even considered doing it like that.
i was thinking of seeing if an 8v gti dual outlet will fitt on the back and set it up pretty much like normal using random hoses from bbm
All Praise The GTI
cheers sam. i was going to order a mi heater matrix hose as realised it would fitt. its just the turbo feeds etc that have confused me. think ill just have to order some hoses and mess around with them
