boldy205
306 Brakes
boldy205
Hi, i have saerched but didnt come up with a real answer i can be sure of. I am currently looking at a brake upgrade for my 1.9 Gti. I presume 306 Gti6 brakes are 283mm diameter with slightly thinner disks than the 307 HDI setup, and that the 307 HDI setup can hit the wheel weights when the weights are mounted inside the wheel, though i have never heard of people having problems with the 306 GTi6 brakes.?? anyone know if the 306 Gti6 brakes hit the wheel weights? Also which car do the 266mm brakes come from and are they worth fitting to a Mi16 205 used on trackdays?
Matt
rapidmi
ive never had weights on the inside but id immagine that they would defo hit them if your running gti6 brakes on a 19 gti wheel theres only space for a rizzla paper between the caliper and the inside rim
boldy205
ok thanks. So how about 266mm brakes? anyone used them in track conditions in an Mi 205?
tom_m
have you actually run out of brakes yet?
decent pads and good fluid worked all day at donnington without too much hassle
As said the std 205 brakes if in good condition are pretty good, The GTi6 brakes add allot of weight to the sprung weight, one reason why I tend to stick with std or go for the 4 pot brembo's but only certain wheels can be used with them
boldy205
Yup have had a very scary experiance on the 2nd chicaine at Castle Combe, good job there was run out!! I need new anyway so thought i may aswell upgrade.
