sutol
Chain Drive Is Slack
sutol
Chain drive to oil pump is not as tight as I'd like it ( is anything ) how much slack is too much do ya reckon.
Am I worrying unnessesaraly unesesserrily unnessesserily without cause. ? :blush:
Ryan
It doesn't need to be tight, as long as the chain can't come off then it should be fine.
sutol
Thanks mate, I suppose you're right, but I worry too much I'm told.
The one on my TD was slack after 100k so I s'pose it's normal.
Do you know if the oil pump is any better on the TD ? :blush:
I believe it would be the same pump, if you want to uprate it to a higher pressure you can fit a pressure relief spring from an XU10 oil pump, you can get them from a dealer for about £3 (not the tenner you often see on ebay :blush: )
sutol
Thanks, I think I'll stick the diesel one on as it is a known good one and I'm not sure of the mileage on the Mi.
Started taking the cambelt off just before tea, a five minute job thinks me.....noooo, first adjuster pulley cracked off after sticking a tube on the allen key and hammering the key into the bolt as I teased it with the bar. CRACK, off it came just as I was about to give up.
Second adjuster pulley wouldn't budge so its sat there daring me to strip it and ruin the bolt, I think I'll weld a nut on it tomorrow and see how we go, new pulleys going on as the motor has been stood a while so I can burn em off if ness. :)
Nothings easy is it :D
