Silky
205 Gti Rocker Cover Gasket
Silky
I have a new 205 GTI rocker cover gasket and a spare rocker cover sitting at home, now I need one for my 306 XSI, any idea if they are the same ?
I dont think they are as the XSi has an oil filler as part of the cover does it not?
I'll check Servicebox for you now.
Bakes100
I dont think they are , as when i replaced my 306 xsi 8v rocker cover gasket i was given the wrong one by peugeot , i think they gave me the 205 one as it was too thick.
Also peugeot have different part numbers for the two gaskets.
EDIT: welshpug beat me to it lol
...it is the same shape as the 205 one underneath just the large box is sticking up out the top of the cover.
Warning when removing the rocker cover though you will need to either loosen the master cylinder or loosen the engine mounts as the plastic casing doesnt get past it!
Edited by Bakes100
0249 71 GASKET - ROCKER 15.08 GBP 17.72 GBP is the one you need :lol:
same part number for the XU7JP and the very late XU5JP.
Silky
That part number for the 306 rocker gasket mate ?
Silky
Cheers fella, will take care with that
yes indeedy :lol:
Silky
Dont suppose you can get a part no. + price for the inlet manifold gasket, 306 XSI 8v again, think they are 4 separate circular rubber ones
Edited by Silky
Silky
Don't worry, I've found it using the servicebox as per your link
yeah looks like it has a plastic manifold with 4 individual o-ring type seals and some smaller round seals.
0348N0 MANIFOL GASKET 10.75 GBP 12.63 GBP
