jord294 89 Posted February 23, 2008 hello people i have a base model 205, which i am using while i rebuild my gti i have lowered the front on it today with some spare -60mm springs, i had lying around. looks kinda cool now, apart from the rear i'd like to get the car sitting quite low, with a slight street sleeper look. question is, how low can i drop the rear without it looking too much? being a base model, i know rear arches are different to gtis, so if any of you can give me an idea, it would be much appreciated if you have pics, even better. it also has the 14" gti wheels on it, but i may be putting 15" steelies on it thanks Share this post Link to post Share on other sites
djinuk 2 Posted February 24, 2008 i know i am going to get crucified on here for doing this but here you go, i get no scrapes etc but i have no rear seats so its quite light. Share this post Link to post Share on other sites
danpug 1 Posted February 24, 2008 If you ever have people in the back of your car don't go that low!! You end up replacing the fuel pipe in the arch very frequently. Share this post Link to post Share on other sites
jord294 89 Posted February 24, 2008 i know i am going to get crucified on here for doing this but here you go, i get no scrapes etc but i have no rear seats so its quite light. did you have the arches rolled for the 15" wheels to fit? i think that might be a touch too low. but thanks for the picture i never carry back seat passengers, only parts for pug gtis Share this post Link to post Share on other sites
TRYNKEEPUP 0 Posted February 24, 2008 i once had a 1.1 205 lowered 60mm all round, i had 1.9 wheels with 195/50/15, after much inner arch tickeling with a hammer i could carry 4 people and had minor scrapes on rough roads, but if your running 14s with 185 tyres i think you should be ok with 60ish mm.i once had a 1.1 205 lowered 60mm all round, i had 1.9 wheels with 195/50/15, after much inner arch tickeling with a hammer i could carry 4 people and had minor scrapes on rough roads, but if your running 14s with 185 tyres i think you should be ok with 60ish mm. Share this post Link to post Share on other sites
jord294 89 Posted February 24, 2008 nice one well at the moment the top of the front tyres are level with the front arch. i'll have to see if i can get the rear looking the same. will post up before and after photos once i get chance. cheers Share this post Link to post Share on other sites
paul205mi16 4 Posted February 25, 2008 Mine is on 50mm SPAX and it is defo to bouncy (on bump stops!) & uncomfortable around this area, The rear is lowered by 2 splines 30mm ish I think, I'm saving for some new Billies though then Im sure it will be much better Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted February 27, 2008 On a non GTI, you can go pretty low on 14" wheels, but 15 Speedlines are a real pain. The offset of 14" wheels is much less than the 15" so they sit further in. My previous non GTI had 15's on and caught a lot, even without lowering Share this post Link to post Share on other sites
jord294 89 Posted February 27, 2008 well i was gonna put some 15" speedlines on the car when it was lowered at the rear but looking at how the front sits now, i think i'll stick with the 14"s and paint them white. cheers Share this post Link to post Share on other sites
j_turnell 134 3 Cars Posted February 27, 2008 I had 15's on my XS, if you run decent dampers, had Konis and 45 profile tyres no problem with rubbing at all Share this post Link to post Share on other sites
jord294 89 Posted February 29, 2008 here's a picture showing the car on std springs and 15" speedlines and after fitting the shorter springs i didn't know what sort of drop the new springs were. but when i initially measured distance from centre of wheel to edge of wheel arch it was 370mm after fitting shorter springs, it was 300mm Share this post Link to post Share on other sites
tom_m 0 Posted February 29, 2008 i didn't know what sort of drop the new springs were. but when i initially measured distance from centre of wheel to edge of wheel arch it was 370mm after fitting shorter springs, it was 300mm too low IMO! Share this post Link to post Share on other sites
paul205mi16 4 Posted February 29, 2008 Blooming hell, Thats really low evan with 14" wheels. Share this post Link to post Share on other sites
jord294 89 Posted February 29, 2008 it seems to drive ok. no nasty knocking noises only a 1.1, so not designed for high speed cornering Share this post Link to post Share on other sites
bales 1 Posted March 1, 2008 I know mine is a gti but this is mine dropped one spline at the back and lowered on coilovers at the front to match. I think it sits very well personally and I havent had any arch issues whatsoever. Share this post Link to post Share on other sites
DaveW 6 Posted March 1, 2008 One spline on a gti beam did have gti shocks too, if you lower yours fit a gti arb and shocks to try stopping the tyre rubbing. Share this post Link to post Share on other sites
jord294 89 Posted March 1, 2008 will give it a go then. cheers everyone Share this post Link to post Share on other sites
