5150maxie 0 Posted February 23, 2008 this may have been ask before, can i swap my 2 row ecu and loom and use a 3 row loom and ecu? i know i will need a lambor sensor but is that it? Share this post Link to post Share on other sites
Baz 421 Posted February 23, 2008 Yep, as long as you swap the whole lot out, loom, ecu, knock sensor. Not necessarily lambda depending on which ecu/loom you have. Share this post Link to post Share on other sites
5150maxie 0 Posted February 23, 2008 Yep, as long as you swap the whole lot out, loom, ecu, knock sensor. Not necessarily lambda depending on which ecu/loom you have. can i fit a knock sensor to mine pretty easy? Share this post Link to post Share on other sites
welshpug 1,627 Posted February 23, 2008 yeah, just bolt it to the block. Share this post Link to post Share on other sites
jackherer 543 Posted February 23, 2008 You need the stud it fits to as well, your engine will have a bolt that you need to change for the correct stud. Share this post Link to post Share on other sites
5150maxie 0 Posted February 23, 2008 You need the stud it fits to as well, your engine will have a bolt that you need to change for the correct stud. what modals can i get one of other than a mi16? Share this post Link to post Share on other sites
