notamondayfan
Fuel Regulator Query
notamondayfan
hey guys
what do i connect up to each part on this fuel regulator? i think the one with the pipe connected goes to the carbs, and one above is the return, and the one to the right is the feed from the pump, but then theres the one at the bottom.
any ideas? cheers, dean
edit - uploaded pic
Edited by notamondayfan
Owain1602
Is it for turbo applications? Looks like the turbo one?
Rob Turbo
If it's anything like my fse, the one on the right will be the feed from the pump and the one on the bottom will be the return, as for the other 2, is it not 2 outlets, like one for each carb?
notamondayfan
owain- its for carbs, not turbo sadly B)
rob -thats what i thought. the right one has an arrow pointing inwards, so i thought that would mean fuel in. the one with the pipe connected has an arrow pointing outwards, indicating fuel out. the other pipe on the left though has an arrow pointing inwards, and the pipe at the bottom doesnt have any arrows.
Owain1602
Im sure, its for carburettor cars with a turbo.
Top one is turbo in
One below that on the same side is outlet to carbs
One on other side is high pressure in
Bottom one is return to tank
99% sure
notamondayfan
stumbled accross this, and they are selling them as parts for carb conversions. so would i be able to blank off the top one and use it as normal if it is desinged for turbo use?
Rob Turbo
Do the carbs have a return pipe? If so, that would go to the other pipe on the left?
If it was for turbo use then one of the pipes would be a lot smaller for a vac/boost pipe to go on to up the pressure when it comes on boost.
Owain1602
it is for turbos!
Thats from FSE site
You can clearly see that the top connection is above the diaphragm therefore its used to influence fuel pressure, like on a turbo!
I cant say anymore.
Edited by Owain1602
Rob Turbo
I stand corrected!!
It just seems a bit big for a pipe from the turbo, they are usualy only small pipes!
Owain1602
If i remember right the fittings can be removed and replaced with other sizes, i seem to recall being supplied with the wrong thread a few years back for a regulator.
