dave_gti 0 Posted January 24, 2008 dont spose anyone could tell me how to get the negative off my coil, this is my engine http://img.photobucket.com/albums/v721/dav...pg?t=1201183361 needed for a sequential shift light Share this post Link to post Share on other sites
dave_gti 0 Posted January 24, 2008 Pic Of The dizzy/coil click here i assume it must be one of those wires, there is Red, Grey, Yellow and Purple Share this post Link to post Share on other sites
jackherer 543 Posted January 25, 2008 Are you running an aftermarket ECU? That looks like a wasted spark coilpack, so it will have a positive and TWO negatives. I'm not sure how that will affect wiring your shift light. If your rev counter works and is the standard 205 one then you must have some sort of tacho converter or ECU output that I guess you could tap into under the dash (wire 112). Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted January 26, 2008 btw, on a standard coil, it's the purple wire: http://projects.205gtidrivers.com/205mi32-...205Mi32_Ph8_077 Share this post Link to post Share on other sites
dave_gti 0 Posted January 26, 2008 btw, on a standard coil, it's the purple wire: http://projects.205gtidrivers.com/205mi32-...205Mi32_Ph8_077 will i be able to use the purple wire then?, and what do u mean wasted coil pack? Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted January 27, 2008 i'm not sure about that. wasted spark means that it sparks on 2 cylinders at a time, with one spark being wasted, unlike when you have a distributor. Share this post Link to post Share on other sites
