notamondayfan
What Clutch For Mi16
notamondayfan
hey guys
i have an mi16 block, with a mi16 flywheel, but no gearbox or clutch.
i also have a complete 1.9 gti engine and gearbox, currently in the car.
i would like to know whats best to do? do i buy a new clutch (and presumably the other clutch parts?) for the mi flywheel, or can/should i just fit everything from the 1.9?
cheers, dean
returnofjim
Definately buy a new clutch for the mi flywheel, ive drove an mi with a 1.9 flywheel and clutch setup and it didnt handle the mi power well at all. A used 1.9 8v clutch will wear out in no time!
notamondayfan
ok so what else would i need apart from the clutch? and wheres the best place to get them?
returnofjim
Hi, GSF (www.gsfcarparts.com) sell a valeo clutch kit which includes driveplate, pressure plate and release bearing which is everything you should need. Also while the box is off i would fit a new primary shaft seal and some new clutch release fork bearings (bushes). The clutch kit is around 60-70 quid! which is a bargain if you ask me.
Edited by returnofjim
notamondayfan
ok thanks thats great!
But only if they special order it, Or you will get a LUK kit
notamondayfan
whats the LUK kit?
Super Josh
You can't fit a standard jetronic model 1.9 flywheel anway because it doesn't have the timing teeth like the MI one. That's assuming your are going to run the standard MI injection.
Josh
notamondayfan
its on carbs, so would that make any difference?
notamondayfan
went to gsf yesturday, and and they said there is a split in the chassis numbers, and consequently two different clutches. i thought there was only 1.9 16v? does the chassis number affect the engine design in anyway?
cheers, dean
C_W
It'll be 1.9 vs 2.0 16v engines. Go for the early one as a safe bet.
LuK clutches are fine, that's what I've got in mine.
