Tony_205 1 Posted January 20, 2008 Hi all, im a bit stuck lol, On the bottom of the throttle body, next to the vacuum advance inlet, there is another brass water connection - - any idea which tube fits onto that connection and where does the tube lead to? After having done a top end rebuild, iv fitted the inlet manifold with all new gaskets bolts etc, i have just realised that i havnt fitted this pipe Any ideas? Thanks Tony Share this post Link to post Share on other sites
djinuk 2 Posted January 20, 2008 on mine its simply not used, and is covered with a rubber blanking cover Share this post Link to post Share on other sites
welshpug 1,627 Posted January 20, 2008 there's a test point that'll usually have a blanking plug as mentioned, the 2 water pipes are quite bit larger. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 20, 2008 You on;ly need to stick the water pipe from the expansion bottle to the top of the stat housing, Bypass the T/B all-together as you don;t need a heated one Share this post Link to post Share on other sites
Tony_205 1 Posted January 21, 2008 Thanks for the replies guys but its still not answered my question really... If there is no pipe on the inlet manifold then water trickles out... This might be a better question; Where do the two pipes from the header tank go? 1 goes to the radiator and one goes under the air flow meter, then goes ??? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 21, 2008 Above the Stat housing, thats why I posted that the right side of the expansion bottle should just go to the stat housing instead, less pipes and less chance of a leak and if you want to remove the inlet allot less hassle Share this post Link to post Share on other sites
Tony_205 1 Posted January 22, 2008 Ahhh right... Got ya mate thank-you Share this post Link to post Share on other sites
