maz89 0 Posted January 19, 2008 Got hold of some 306 ap racing brakes. What new parts do i need to fit them to a 1.6 gti?? Share this post Link to post Share on other sites
Tom Fenton 1,526 Posted January 19, 2008 You will need a set of 205 GTI 1.9 hubs to be able to fit the discs and calipers, the 306 disc offset is the same as a 205 1.9, but different from a 205 1.6. To allow you to fit the 1.9 hubs, you will also need a pair of 1.9 driveshafts. The rest of the suspension will fit with no issues. So; to sum up, you need the hubs and driveshafts from a 205 GTI 1.9. Share this post Link to post Share on other sites
Jrod 7 Posted January 19, 2008 Or a set of base model hubs and retain 1.6 shafts. Share this post Link to post Share on other sites
cybernck 400 1 Cars Posted January 20, 2008 slightly off topic, but Jrod, a friend has asked me today if he can swap his 205 XS front suspension for a 205 GTI 1.6 setup and i was sure on everything bar the driveshafts. do you reckon they will fit the 1.6's hubs ok? Share this post Link to post Share on other sites
danpug 1 Posted January 20, 2008 Why dosen't he just stick with the xs hubs? Share this post Link to post Share on other sites
ifcho 0 Posted January 20, 2008 slightly off topic, but Jrod, a friend has asked me today if he can swap his 205 XS front suspensionfor a 205 GTI 1.6 setup and i was sure on everything bar the driveshafts. do you reckon they will fit the 1.6's hubs ok? I'm using 1.6GTI driveshafts on a car that was a base model with TU engine, with the standard hubs (TU, base model hubs), so I guess he can use them vice versa Share this post Link to post Share on other sites
Jrod 7 Posted January 20, 2008 slightly off topic, but Jrod, a friend has asked me today if he can swap his 205 XS front suspensionfor a 205 GTI 1.6 setup and i was sure on everything bar the driveshafts. do you reckon they will fit the 1.6's hubs ok? I didn't know you could use 1.6 shafts on a MA box but if 1.6 shafts fit in base model hubs I guess it will work the other way around. Personally I'd use base model hubs as it just gives you more choice for brake changes in the future. Share this post Link to post Share on other sites
