DamirGTI 345 Posted January 18, 2008 (edited) Hi ! I was wandering wheres the difference in between 1.9 D6B and DKZ engines ? i know that DKZ engine has "mild" cam but is that all or is there something else like - different piston crowns , combustion chamber depth etc. ? Why this DKZ engine has lower CR compared to D6B engine ? Thanks ! Damir Edited January 18, 2008 by DamirGTI Share this post Link to post Share on other sites
petert 611 Posted January 18, 2008 Hi ! I was wandering wheres the difference in between 1.9 D6B and DKZ engines ? i know that DKZ engine has "mild" cam but is that all or is there something else like - different piston crowns , combustion chamber depth etc. ? Why this DKZ engine has lower CR compared to D6B engine ? Thanks ! Damir The pistons have a bigger dish to give 9.2:1. It has the same head. Share this post Link to post Share on other sites
DamirGTI 345 Posted January 18, 2008 The pistons have a bigger dish to give 9.2:1. It has the same head. Then the camshafts are the same ? I have some data for valve lift and there says : Intake valve lift : 11.3 D6B - 11.0 DKZ Exhaust valve lift : 11.3 D6B - 11.0 DKZ Anyway if i fit D6B pistons in DKZ engine it'll have same CR as D6B engine , or not ? Thanks ! Damir Share this post Link to post Share on other sites
petert 611 Posted January 18, 2008 (edited) Then the camshafts are the same ? I have some data for valve lift and there says : Intake valve lift : 11.3 D6B - 11.0 DKZ Exhaust valve lift : 11.3 D6B - 11.0 DKZ Anyway if i fit D6B pistons in DKZ engine it'll have same CR as D6B engine , or not ? Thanks ! Damir No, as you said, the cam is different. They have the similar lift but less duration. Yes, you could fit D6B pistons to bring the CR up to 9.6:1, but I'd just skim the head if the pistons/liners are in good shape. A skim of 1-1.2mm should give 10:1. Edited January 18, 2008 by petert 1 Share this post Link to post Share on other sites
DamirGTI 345 Posted January 18, 2008 Excellent , thanks for info Peter ! Cheers Damir Share this post Link to post Share on other sites
