si_03
1900 Head On 1600
si_03
this has prob been ask many a time but sorry. does the 1900 head and cam fit the 1600, is there anything i need to look out for or is it straight foward
cheers si
ginjaspeed
The heads are identical, the only thing to watch is the length of the headbolts, if your's has hex headed bolts these are shorter than the torx headed ones. just make sure that you use the correct washers if you fit the other type of head bolt!
