pp205
1.9 Mi16 Ignition Coil And Wires
pp205
Hi, have been trying to sort my loom out today but found that the multiplug that goes onto the coil had been chopped off :P
can somebody please tell me which wire does what and what colours they are meant to be?
There are a blue, yellow, lilac and a thick green shielded one. I have the coil multiplug from my 205 loom so I will fit that on the mi coil.
I have done a search by the way and not found much
Cheers Simon
pp205
Ok, not too sure why this has been moved here as this has nothing to do with aftermarket engine management :rolleyes:
Please can somebody post a picture of their 1.9 mi16 coil and multiplug with the little plastic cover pulled back so I can see which order the wires go into the multiplug so I can copy it for mine as someone had cut it off.
Cheers Simon
Stu
Ive got a diagram on my other computer mate, ill sort it in the morning along with a piccie for you.
Stu
Here you go fella, cant find the diagram, but its easy enough to see what goes where.
Hope this helps!
