pee vee
Squeeeeeeel!
pee vee
all of a sudden the other day, after the car got up to full temp.
when coming to idle, and up to about 2k rpm, there is a horrible squeel
Almost like someone blowing a whistle, coming from my engine!!!
as soon as you load the engine to pull away, it dissapears. until you are just crusiing along..
my initial thought was a leak around the inlet manifold gasket,
but thought i'd try spraying some WD40 round it to see if anyhting was obvious.. but it made no difference..
Do fuel pressure regulators squeel if they have gone wrong!?
as thats where it seems to be coming from. lol
is the 1900 8v one the same pressure setting as the Mi16 one???
as i have a spare one if so..
thanks!
Phil
EDIT: its not the belt slipping! noise isnt coming from that area!
Edited by pee vee
mechsmurf
i have same squeel but mine is only realy when could i have found that the throttle body is clogged up with mayo oil and has clogged all the pipe going to vac advance i cleaned it all out and all was ok again till today its clogged up again
