M_R_205
Need A Pic / Diagram Of The Rear Brake Lines
M_R_205
the mot`er is DEMANDING that i fit a rubber flexible hose to the back of my pug insted of the straight braided line i have on atm, does anyone have an image or diagrm of that area as i cant for the life of me remember how it looks,
(will get and MOT eventualy!!!!)
Cheers :)
I've not got a picture of the full run but iirc there should be a bracket on the underside of the shell behind the tank on each side (on a 1.9, the T piece on the 1.6 has a female union instead) which the flexi is held into by a clip & the solid line union threads into, the other bracket is on the lower shock bolt & the flexi loops round to this & swaps back to a solid line, either right to the caliper or to the bracket behind the caliper for the flexi to the caliper on the 1.9 GTi.
I've got a couple of pictures showing pictures of this if you need them (mainly the brackets on the beam), let me know & I'll post them up.
The solid pipe loops out of the front of the flexi then bends round to run along the radius arm to the next bracket / wheel cylinder.
Graham.
