Guest SuperFLY
Nooooo Heater Matrix Is Fekked!
So, what about replacing the heaters fan?
Any tips on that?
Easy, same areaas swapping the fan resistor that adjusts the fan speed with dial position, three screws hold it into the heater housing & one plug (brown iirc) connected to it in passenger footwell under dash.
You can try oiling the bearings for the fan to quieten it down but finding a better quieter motor & oiling that can be better & more long term.
Graham.
Guest LittleRocket
Cheers everyone. I've not had chance to repair it yet - but aim to look at it next week. I've tasted the solution - and its definitely coolant - quite addictive I thought :) . I'm hoping it's just going to be the rings - as there is no damp in the footwells - just drips inside the stereo slot. I think I'll be able to fix it if I just print this topic off.
GLPoomobile
Sorry, but it's more likely to be the matrix. If the rings were leaking the coolant would drip off the elbow on the pipes and collect in the drivers footwell. If it's collecting above the stereo it sounds like it is leaking from the matrix core.
Guest LittleRocket
Just to let you know - I took the Heater Matrix out - didn't bother replacing it - piece of piss. I just joined the hoses up that were connected to the bulk head with a piece of copper. Then my immobiliser packed in :) . I've taken it out altogether now - more problems than benefits with that thing.
I've tasted the solution - and its definitely coolant - quite addictive I thought :P .
coolant is extremely toxic, don't drink too much :(
however if you do drink a lot the antidote is alcohol so get on the spirits asap :)
hengti
don't drink any!
there was a case in the news recently of a guy who was left brain damaged after consuming only a small amount - his workmate (they worked in a garage) poured about 1-2 inches of a'freeze into a cola bottle, which the guy then drank from
can be very dangerous
only taste it on the end of a finger
then you can start on the Vodka :)
