boldy205 74 Posted December 14, 2007 Hi, is it possable to share maps for cars, i have a 205 Mi16 (alloy block) on twin weber 45s, which appart from the carbs and the megajolt, is standard. Does anyone have a base map for onr of these, something to get me started? is it ok too ask or is this very cheaky? Its seems a little cheaky to me but hey, why not ask!! Thanks Matt Share this post Link to post Share on other sites
Jer309GTi 3 Posted December 14, 2007 (edited) Then I can rob them off you for mine too Matt Edited December 14, 2007 by Jer309GTi Share this post Link to post Share on other sites
Tom Fenton 1,525 Posted December 14, 2007 If you have a look on the Emerald website there are some sample maps, one of them is an Mi16 map, obviously you will need to adapt the numbers to suit your MegaJolt setup, but should give you a starting point at least. Share this post Link to post Share on other sites
boldy205 74 Posted December 15, 2007 Hi Tom, thanks for the info, i have looked on the site but cant seem to find what im looking for, any chance of sending it to me in a link please? Thanks Matt Share this post Link to post Share on other sites
stu_woac 1 Posted December 16, 2007 have you cheack on the megajolt site its self as there is a map database on there not saying its up there tho I know a map was for my mates v8 landy Share this post Link to post Share on other sites
petert 550 Posted December 17, 2007 Does anyone have a base map for onr of these, something to get me started? I thought the search function was fixed? MAP LOAD SENSING http://forum.205gtidrivers.com/index.php?a...ost&id=2144 TPS LOAD SENSING http://forum.205gtidrivers.com/index.php?a...ost&id=2146 Share this post Link to post Share on other sites
boldy205 74 Posted December 17, 2007 Hi Petert, thanks for that, i didnt find that in the search, just out of interest what did you type in the search or did you have the links already? Thanks Matt Share this post Link to post Share on other sites
petert 550 Posted December 17, 2007 I already had the links from this post: http://forum.205gtidrivers.com/index.php?s...mp;#entry685086 Share this post Link to post Share on other sites
davemar 16 Posted January 11, 2008 I thought the search function was fixed? MAP LOAD SENSING http://forum.205gtidrivers.com/index.php?a...ost&id=2144 TPS LOAD SENSING http://forum.205gtidrivers.com/index.php?a...ost&id=2146 Are the values in degrees advance? I assume the column on the left (1...15) is the MAP or TPS value. Is there a conversion from this value to an actually pressure value (for MAP) or throttle angle (for the TPS, assuming that's what you'll measure)? Share this post Link to post Share on other sites
boldy205 74 Posted January 11, 2008 Not totaly sure what you mean, one link is for TPS, which is calibrated for the particular TPS setup, and the other is a MAP which is generaly stated in presure. The Values given are in degrees advance. Matt. Share this post Link to post Share on other sites
davemar 16 Posted January 14, 2008 Not totaly sure what you mean, one link is for TPS, which is calibrated for the particular TPS setup, and the other is a MAP which is generaly stated in presure. The Values given are in degrees advance.Matt. The TPS and MAP values are just given as 1 to 15. Is there a conversion to the actual pressure values for the MAP values? I understand measuring and defining a TPS opening might be a little trickier. Share this post Link to post Share on other sites
boldy205 74 Posted January 15, 2008 I dont know it if there is one im afraid, as i have only been involved with a TPS Setup. Surely someone on here can sus it out? Share this post Link to post Share on other sites
