Craigb
Driveshadft Options
Craigb
Moving on from James thread about driveshaft availability, I thought I would start to look at the 205 only options for replacement shafts, and also how and where people’s shafts have failed
Currently I believe the options are
1. New Peugeot Shafts still available at £188
2. OE reconditioned shafts at £128
3. GSF GKN shafts at £90 ish
4. GSF none GKN shafts at £70 ish
Outside of these options are custom shafts at about £1000 ea
As far as I can see the differences are
Option 4 No guarantee
Option 3 sometimes comes with a life guarantee
Option 2 has a thicker shaft (by 1.2 mm)
Option 1 has rolled splines rather than cut splines (in theory should be stronger)
Modes of Failure
a) outer CV fractures
:rolleyes: shaft snaps in the outer CV
c) inner CV fractures
d) shaft snaps in the inner CV
e) tripod collapses
Can a poll be set up on here ?
If so can someone set up one with the modes of failure above ?
Edited by Craigb
Another option is to have a word with Sandy309's mate Colin Satchell - he makes custom shafts based (I think) on heavy duty 406 CV's that are meant to be very strong and competition proven. Can't remember the exact price, but I recall that they weren't too bad at all - £200 a piece rings a bell, but might be wrong.
Otherwise, for road and occasional track use, I've never (yet) had a problem with GKN driveshafts and for the money I can't really fault them. Not sure they'd survive competition use with a plate diff so well mind you.
Craigb
I forgot to add , that all of the failures i have had have been d ) snapped shaft at the base of the splines going into the inner CV on the nearside.
Thats with GKN shafts !
steve@cornwall
I've had numerous failures due to the tripod roller bearings over the years. Just put new (scrappy ) tripods or rollers in - occasionally also replaced the part that goes into 'box as well, as they can get badly mangled with loose bearings. That and outer CV wear (knocking when cornering) - these can give donor tripods etc. before chucking. Maybe in future I should keep the old shaft too for you over-powered boys :rolleyes:
