ronnie_gti
205 Gti Turbo Conversion
Galifrey
Now I know, that my last post was stupid. Wiring is not enought.
I have got the keypad and the code too, but I want to leave it out.
Connect it all up with the keypad, start the engine (inputting the code) then once started, unplug the ecu plug from the ecu.
Ecu will be unlocked.
Remove the keypad etc from the loom
Now when you plug the ecu back in, it wont relock.
Jamal
Just read through the immo posts and I found another method. "Enter code, start engine, disconnect keypad"
I tried this, but the engine stopped.
So I will try to disconnect the ECU now.
A question: If I reconnect the immo keypad later, it will ask for the code again, so it will work as before the unlocking?
Thanks!
