ORB
Bloody Head Lamps!
ORB
One of my lamps is playing silly buggers.
I put them all back together the other day, one of them works fine and the nearside one does not.
I tried new bulbs and stuff, but no joy, all I get from it on main and dipped is a very weak glow from the bulb?
Whats you thinking boys?
steve@cornwall
Bad earth! Check the block connections on the front panel behind affected lamp.
ORB
There is a good idea!
Where exactly will I find the earth?
my car is a phase 1.5 if that helps
steve@cornwall
Screwed to the front panel, below and slightly inboard of the headlight, facing the engine should be a multi-male connector block of different earth wires. It may have a plastic boot covering it.
ORB
i know the one.
i am off to look now!
Simes
Remove the block and remake the terminations (both sides) - you'll be surprised what a difference it will make.
pete1986
Hmm... think ill try this as well. Mine are are also a bit dim but still drivable
