matt-k 0 Posted December 2, 2007 Hi sorry if im not using the technical names but i cant remember them! The rubbers on the pins that locate in the bottom of the hubs have perished and split. Im guessing this is an MOT failure. How do i re-move them from the lower arms and can someone tell me there technical name so i can order some more!? Thanks, Matt. Share this post Link to post Share on other sites
philfingers 5 Posted December 2, 2007 Not sure if you can buy them seperately from pug but:- http://cgi.ebay.co.uk/10-Larger-Track-Rod-...1QQcmdZViewItem You'd need to measure them first, can't remember the size off hand. There was another thread about these recently! Phil Share this post Link to post Share on other sites
jord294 87 Posted December 2, 2007 unfortuneatly direct replacement boots for the wishbone are not available new wishbones needed. or if the split isn't serious and joint isn't worn, it is possible to remove the rubber boot, clean with electrical spray, or something that will remove grease, and glue the split. i managed to do this on a set of wishbones i had. Share this post Link to post Share on other sites
