Alan_M 66 1 Cars Posted November 22, 2007 Just a quicky...... Is there anything wrong with using copper brakeline when fitting them to run inside the car? I'm sure there is'nt but just want to double-check. Also, is a bias valve worthwhile given I'm a novice? I was just going to ditch the rear compensators (I'm running 4 pots upfront). Thanks Alan Share this post Link to post Share on other sites
welshpug 1,737 Posted November 22, 2007 should be fine as long as you can clip it down securely, braided is a little easier to use in this respect, but a lot more expensive! Share this post Link to post Share on other sites
Jrod 7 Posted November 22, 2007 I'd of said it was the other way as braided is flexible so needs to be well held down where as copper is rigid? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 23, 2007 Braded is quite cheap, It's the fitting's that cost the money. But no reason not to use Copper line's as many people do, Just use some good clip's to keep it in place and make some nice curves as some are just plain all-full on some car's where it's been bent by hand Share this post Link to post Share on other sites
James_R 3 Posted November 23, 2007 Bias valve can't hurt, or at least put a union in to simulate a bias valve so ones easy to fit if needed. Share this post Link to post Share on other sites
Spiky 37 Posted November 23, 2007 i fitted braided, as well i dont know..lol only issue i can see with copper, is you "could" put a kink in the pipe and they it will affect ya brakes, and you "might" not notice it where as braided is fairly flexiable Share this post Link to post Share on other sites
Alastairh 47 Posted November 24, 2007 Copper is fine. Seen loads of 205s with them fitted with decent clips securing them. Share this post Link to post Share on other sites
Redtop 14 2 Cars Posted November 24, 2007 Coniffeur sp is a better job than copper. It's a bit dearer and slightly tougher than copper and harder to bend but does a good job. Ive both my 205's done with it but they are in the original brake pipe postions. I think it has a better fit at joints as it doesn't squash as copper to get a good seal. Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted November 25, 2007 OK, sounds like copper will be fine. For now I think I'll do without a bias valve, and just put a union in its place. Can someone tell me the size of fittings I need? I want to ditch the compensators at the rear as I have 4 pots upfront, and still use my goodridge hose ends at the calipers. The MC(which I am replacing) fittings are M10x1 male, what are the fittings where the flexi/goodridge pipes connect? Basically, I'll be running 2 lines for the front, and 1 to the rear where it'll split around the fuel tank to each caliper. Is it an idea to change the lines at the MC to represent front/rear split, as I suppose its diaganolly split ATM? Share this post Link to post Share on other sites
James_R 3 Posted November 28, 2007 I've plumbed mine with the front outlets to the front then the one at the back to the rear and blocked the remainder. You can just use a std Tpiece under the car or even a 1.6 T-piece and flexi's. The other advantage of braided (or at least going braided from the underside of the shell on the run, is that when you pull the beam off, you just unbolt the caliper and place it on the floor in the middle of the car, and drop the beam off, no need ot bleed the system makes life easier there. Share this post Link to post Share on other sites
Anthony 1,003 Posted November 28, 2007 Can someone tell me the size of fittings I need? All the fittings are M10x1 as standard, but obviously the bias valve will be whatever the manufacturer of it felt like - I know Wilwood bias valves use a wierd tappered thread, and hence I'm not sure there's much point putting a union in the line as it might not be the correct one. Absolute worse case is having to remake the whole front-back line to fit a bias-valve at a later date, which is only about an hours work and less than £5 of copper pipe/unions. Is it an idea to change the lines at the MC to represent front/rear split, as I suppose its diaganolly split ATM? That's what I usually do as a matter of course (single line to rear), and you'll need to do that anyway for fitting a bias-valve. The other advantage of braided (or at least going braided from the underside of the shell on the run, is that when you pull the beam off, you just unbolt the caliper and place it on the floor in the middle of the car, and drop the beam off, no need ot bleed the system makes life easier there. You can do that with copper too (that's what I do every time I have to remove/refit a beam) but granted it's 10 times easier with braided. Could have the best of both worlds - copper inside the car and as far as the T-piece, and then braided from there to the calipers? Share this post Link to post Share on other sites
Rippthrough 98 Posted November 28, 2007 If your just running hard line in the car then it'll be fairly straight, so you could use steel without too much hassle. Share this post Link to post Share on other sites
M3Evo 0 Posted December 2, 2007 All the fittings are M10x1 as standard Except one of the ones on the compensators themselves which are M12xsomething-or-other I seem to remember (just incase anyone reading this is doing a replacement for standard pipes. Share this post Link to post Share on other sites
Guest smokinslim Posted December 3, 2007 Yup, the newer 1.9 compensators are m12x1 at the front end, m10x1 at the back. The older ones were m10x1 both ends. God only knows why they changed it, jus to be bloody akward probably lol. Share this post Link to post Share on other sites
Anthony 1,003 Posted December 3, 2007 Good point and thanks for making that clear - I was talking about the compensatorless setup Alan wanted, but most people who are retaining the compensators will indeed need a couple of M12x1 unions, one for the two compensators. Share this post Link to post Share on other sites
James_R 3 Posted December 3, 2007 Think the wilwood jobs are 1/4 npft or something like that a weird american size *spits* But they usually come with two adaptors from 1/4npft to M10 male female, you just screw them in with lots of threadlok and you're away, just leave the adaptors in over night to set off before you want it all on the car so they don't leak (although sometimes they still do) then use a M10 female female or the bias jobby in There's almost no cost difference in replacing the centre run with a copper pipe, since the unions are the bit that get you the pipes relatively cheap although mounting all the p-clips is a PITA Share this post Link to post Share on other sites
philfingers 5 Posted December 4, 2007 I'd be inclined to use cable tie mounts/ saddles. http://cgi.ebay.co.uk/Screw-anchor-cable-t...1QQcmdZViewItem It's easier to pop rivet the saddel in place then cable tie the copper down on to it, easier when you want to get it out too. Share this post Link to post Share on other sites
