dodsworth_gti 11 Posted November 16, 2007 (edited) hi im struggleing to find the fuel pump housing for my tank,so im now thinking of other ways of doing it as im planning on doing something to the engine at a later date,i thought i could well get the pump now ready for it im thinking about running a facet pump on it but i dont know if they are adjustable,or which one i should go for competion silver top Pressure (Psi): 5.0 - 6.5 Rate (Gals/hr): 25 red top Pressure (Psi): 6.5 - 7.25 Rate (Gals/hr): 38 silver top Pressure (Psi): 4.0 - 4.5 Rate (Gals/hr): 18 Facet Solid State Fuel Pump - Road Pressure (Psi): 2.5 - 3.0 Rate (Gals/hr): 12 many thanks ben Edited November 16, 2007 by dodsworth_gti Share this post Link to post Share on other sites
Stu 18 Posted November 19, 2007 If you are stll using the stock injection mate none of those pumps are high enough pressure, iirc the fuel rail is at 3 bar (45ish PSI). Share this post Link to post Share on other sites
boombang 2 Posted November 19, 2007 IIRC the standard 405 Mi16 fuel pump is the same as the 405 T16 fuel pump - so definately has a lot of flow potential and can cope with the pressure. It is also external so doesn't have to be mounted in tank. I've got one somewhere if you wanted to give it a try? Share this post Link to post Share on other sites
dodsworth_gti 11 Posted November 20, 2007 how much would you want for it mate??? sned me a pm please Share this post Link to post Share on other sites
dodsworth_gti 11 Posted November 20, 2007 so if i run a external pump,i could block of the hole,and feed in 2 pipes for fuel lines,maybe fit a filter sock onto the pipe and hope it would still pick fuel up? Share this post Link to post Share on other sites
lee-bg 0 Posted November 23, 2007 You can use the 2 pipes that go out of fuel tank then connect to external pump. Fuel filter can be in front, in engine compartment. Also external fuel pump can give much better flow if u fit an uprate one. 4 bar is nice goal. You will also need adjustable fuel regulator for this to feel the difference. Share this post Link to post Share on other sites
Richie-Van-GTi 70 2 Cars Posted November 24, 2007 save a few quid and get an external ford one from a breakers yard. Last one I got was £10 and flowed a hell of a lot more than my pug pump. Share this post Link to post Share on other sites
