wardy18 33 1 Cars Posted October 26, 2007 Told you id bent them finally got the head off today and sure enough visibly there are #4 exhaust valve and #3 inlet valve not sitting flat and so leavin about a 1mm gap, more are probably bent if i tested them with parafin but ive seen enough on to the next head then quick question, i know there are 3 different 1900 8v heads, the one im about to put on is either the 122 or 130 bhp, can either of these be fitted to the D6B block?! sorry i cant remember the different engine names, please advise Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 27, 2007 Either head will fit but iirc the 122bhp one has larger chambers so it will lower the compression on the D6B engine. A skim would bring it back up again though. Graham. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted October 28, 2007 Either head will fit but iirc the 122bhp one has larger chambers so it will lower the compression on the D6B engine. A skim would bring it back up again though. Graham. yeh im gonna give the head a good skim to get a little more performance out of it but to be honest its a mates pug and he aint too needy for performance as long as its good runner thanx for the reply Share this post Link to post Share on other sites
petert 616 Posted October 28, 2007 Either head will fit but iirc the 122bhp one has larger chambers so it will lower the compression on the D6B engine. I thought it was the same head but different pistons between the 122hp and 130hp. Certainly the 105hp engine has bigger chambers. Share this post Link to post Share on other sites
