Kenno
Gti 6 Timing Belt Change
Kenno
Am gonna do it today or morro but any tips will be helpful please???
Nothing wrong with the old 136 tooth belt and very easy to change, Don;t forget the Pump and Tensionor's at the same time,
just don;t set the engine up using the lower pulley thou as these slip and will give you a false reading and bent valves if started without winding the engine over by hand first, If you;ve got a old 8v pullet kicking around this does the seting up just fine
kyepan
Hi miles, bit confused do you mean lower tensioner? as in don't tension the belt mostly on one tensioner, and not the other higher one. or do you mean crank pully?
confused :P
Set the timing up and the hole in the lower drive pulley (For the alt etc) as this slips and rarely stays in the same place unless you buy a brand new one
