sussex_gti 0 Posted October 14, 2007 (edited) Hi, like most of us, the urge for more power is getting to me. I've got the handling sorted, and the brakes will be done by November. I know everyones going to say i need to search, but its down at the moment. What i'd like to know is, what exactly do i need? I'm not going to rush the conversion, but would like to gather everything i need, to almost do a 'plug and play' conversion. This is an everyday driver for me, so want to get all i need, take a week off work and do it. So, if someone wouldnt mind, a complete list of all i'm going to need would be great. What do you need with regards to clutch/flywheel? I'm keeping my 1.9 box, as its in great shape. Can i use my existing magnex manifold? I'm going to order the BBM hose kit soon, would this work ok with the gti-6? Thanks in advance, Chris. Edited October 14, 2007 by sussex_gti Share this post Link to post Share on other sites
TurboSam 5 Posted October 14, 2007 best thing to do would be to buy a GTi-6 donor car, this is what I did and it made it a whole lot easier, as I had pretty much everything needed.. to use the 1.9 box, get an mi16 clutch kit, which will bolt straight to the gti6 flywheel, and then bolt on the 1.9 box as normal Share this post Link to post Share on other sites
sussex_gti 0 Posted October 14, 2007 Cheers man, Mind if i pm you, ask a few questions? Share this post Link to post Share on other sites
Spiky 37 Posted October 20, 2007 mi16 cluctch 1.9 205 gearbox fits then unlocked ecu the engine loom for the 306, then mated to the 205 loom you need to fabricate some water hoses i've cut the rubber off my drivers side engine mount and dropped the engine and extened the bottom rear mount 10mm then engine fits and dont touch ANYWHERE cut and re weld 205 exhaust and fitting a lambda boss (mine may 176bhp with std exhaust) reno 19 16v oil filter as it's smaller with the alternator, thats up to you, i've used a 1.9 8v one and mi16 brackets, and thats done , some use the gti6 one Share this post Link to post Share on other sites
