Ethos 0 Posted October 3, 2007 Hi guys, Are there any specific spark plugs I should be using? I'm planning on changing them tomorrow, might get them from halfords or mill auto which are both close to me. What should I expect to pay? Thanks. Share this post Link to post Share on other sites
DamirGTI 362 Posted October 3, 2007 Hello ! If it's 1.9 engine then : Non Cat - NGK BCP7ES (or resistor type plug - BCPR7ES) Cat - NKG BCP6ES If it's 1.6 engine : Non Cat - NGK BCP6E Cat - NGK BCPR6E As for the price , well i don't know how much are they in your country Anyhow buy NGK brand these are the best spark plugs Cheers ! Damir Share this post Link to post Share on other sites
Ethos 0 Posted October 3, 2007 Hello ! If it's 1.9 engine then : Non Cat - NGK BCP7ES (or resistor type plug - BCPR7ES) Cat - NKG BCP6ES If it's 1.6 engine : Non Cat - NGK BCP6E Cat - NGK BCPR6E As for the price , well i don't know how much are they in your country Anyhow buy NGK brand these are the best spark plugs Cheers ! Damir Thanks! How do I know if I have a cat or not?! Share this post Link to post Share on other sites
DamirGTI 362 Posted October 3, 2007 Well it's simple Look at the exhaust pipework just after the mainfold and if you have one you will see him inbetween the exhaust mainfold and middle silencer . You will see also the lambda sensor and it's wiring on the exhaust .. But it's possible that someone before you have remove the CAT , in that case look on the engine block just above the alternator and you will see there little plate - on that plate you will see stamped engine code/numbers 1.9 GTi : DFZ and DKZ - are CAT engines D6B - is Non CAT engine 1.6 GTi : I'm not sure which codes are CAT/Non CAT in the case of 1.6 engine but someone from here will know guys ? Anyway which engine do you have ? 1.9 or 1.6 ? Damir Share this post Link to post Share on other sites
Ethos 0 Posted October 3, 2007 1.6 1992, I'll have a look tomorrow morning Share this post Link to post Share on other sites
DamirGTI 362 Posted October 3, 2007 If it's 1992 engine then me thinks that it must be CAT equipped Share this post Link to post Share on other sites
Ethos 0 Posted October 3, 2007 If it's 1992 engine then me thinks that it must be CAT equipped Yea, just reading up. 92 was when cars HAD to have cats by the looks of it. Share this post Link to post Share on other sites
welshpug 1,735 Posted October 3, 2007 the 1.6 engine never had a cat on it, peugeot couldnt get a decent output from the engine and pass the emissions laws so they ditched the engine in late 92. CAT rules didnt come into force untill August 93 either. Share this post Link to post Share on other sites
Ethos 0 Posted October 3, 2007 the 1.6 engine never had a cat on it, peugeot couldnt get a decent output from the engine and pass the emissions laws so they ditched the engine in late 92. CAT rules didnt come into force untill August 93 either. Thanks for the info Share this post Link to post Share on other sites
