Jrod
1.4 Into 1.1
Jrod
Right well I've swapped the dash and got the rev counter working on the little 1.1 :D:)
I'm going to chuck a Xs engine in there but noticed the 1.1 hasa fuel return, is it ok just to block this off as the XS doesn't have one?
Sandy
Shoule be, or run a pipe back if the tank has the connector.
trogboy
The XS should have a fuel return line! From the top of the air release trap (clear plastic thing) next to the fuel pump.
EDIT: Fat typing fingers
Edited by trogboy
Jrod
I've only seen that on the rallye, Never on a XS :D
Sandy, where would I run the pipe back from as the carb doesn't have a connector? :wacko:
Edited by Jrod
Sandy
It's the other way round then?
Jrod
Sorry, i'm really confused lol. :D
Raymondo205
Right well I've swapped the dash and got the rev counter working on the little 1.1 :wacko::D
i've just swapped my standard little 1.0 XE engine for a XS one and was wondering how to go about swapping over the rev counter over from the XS to the XE?
Jrod
Just had to swap the wiring loom for a XS one, pretty simple as it all just unplugs from the fusebox.
Raymondo205
Ahhh thanks, much appreciated :rolleyes:
Jrod
Figured this out now.
The return pipe comes off the little white as you said so you can just use that with the Xs engine and no need to block up the return or anything. :(
Took me 5 hours to swap the engines incuding a clutch and manifold change which I didn't think was to bad. :(
trogboy
not a bad effort. Whose rallye is in your avatar?
Jrod
Mine. :D
trogboy
Eh? not a shot of Sams old shell though is it?
Jrod
Nope, my new one. :unsure:
calvinhorse
more pics! is it a rallye or this one.one?
Jrod
It was a 1.1 shell. :unsure:
DaveW
Fake :unsure:
Jrod
Not according to the V5. :unsure:
trogboy
Does the V5 match the chassis no. though? Plus what engine did it come with?
Jrod
The numbers all match
:unsure:
Edited by Jrod
calvinhorse
naughty! i wont tell anyone!
Jrod
Well 1 side is done. Will do the other side then the car needs a clean. :P
I'm tempted to lose the "Rallye" decals on the door. :unsure:
trogboy
who supplied the PTS flames on the wing? Johnny Goodhand?
Jrod
Yer,
I wasn't sure whether to go original and lose the rear quater badges and the PTS below the flame or just mix the 2 like I've done.
I'm happy with it as it is except the rally stickers on the doors, I don't thionk it matches with the Euro style on the badges. :unsure:
jonnygoodhand
Yer,
Looks good!
I also tried a combination of the two (euro and UK) at one time but currently running with solely UK style:
Did you have any trouble fitting them?
