migti
205 1.9 Gti Non Start
migti
hi all
rite to set the story, out in the car felt like it ran out of fuel. back to house checking over, good spark , smells of fuel when turning over, cleaned plugs ect. no go.
not even a splutter. swaped afm for a good one no diff.
can anyone point me in next steps?
Cheers!!
gti-si
Checked the injectors are praying correctly? ECU? Check all the ignition components again, even thougn you have a spark. It sounds to be like fuel pump or tachy relay, cant understand how it would smell of fuel that way though. Could be massive overfuelling actally. Turn the engine over a few times, then unplug all the injectors and turn it over again, if it fires and runs for a few seconds we know the engines being flooded.
Main cuplret for that would be the ecu temp sender. But just give that a go, see if you get a result
