Spiky 37 Posted July 29, 2007 need to lower the engine, and been told to use the mi16 i understand that, but the 205 engine mount, is this the same as mi16???? Share this post Link to post Share on other sites
Spiky 37 Posted July 29, 2007 dont worry, i tink i know the answer god damm finding one of these (mi16 mounts) is gonna be a nightmare Share this post Link to post Share on other sites
pee vee 1 Posted July 29, 2007 has miles got one spiky?? he seems to have loooads of parts lol Share this post Link to post Share on other sites
Spiky 37 Posted July 29, 2007 i already sent im a pm so will hope e has te bits i neeed Share this post Link to post Share on other sites
jonnie205 1 Posted July 30, 2007 to fit a gti6 engine you need a gti6 mount. no idea if an mi16 one can be used but its seems like more effort and the gti6 alternator setup works well in a 205 Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted July 30, 2007 MI16 can be used and its easier to lower the engine for MC clearance, means you also need the correct alternator and brackets but it is lighter than the gti6 item. Jonnie, can you get any pictures of how you have set yours up regarding tensioners etc please Share this post Link to post Share on other sites
Spiky 37 Posted July 30, 2007 it's ok, i'm going down the mi16 route now and getting rid of gti06 mount, and i'll be using the 8v 1.9 alternator as i need to clear the 406 MC i have Share this post Link to post Share on other sites
Spiky 37 Posted August 3, 2007 MI16 can be used and its easier to lower the engine for MC clearance, means you also need the correct alternator and brackets but it is lighter than the gti6 item.Jonnie, can you get any pictures of how you have set yours up regarding tensioners etc please mi16???? well i have an alloy mi16 engine mount and there is absolutly no chance that is going to fit are are people talking of the s16 mi16????? Share this post Link to post Share on other sites
Alastairh 47 Posted August 4, 2007 (edited) Right. As Martain said in one of your threads putting a S16 mount and 1.9 alloy mount side by side they're is bugger all in it for weight, so people can leave the sean type comments But what i run is (and have done for my brothers old S16) S16 top mount with the arm which also can be had off certain 2.0 8v 306's etc, then you need a Xm alternator mount and alternator from the models that run the second belt and have the power steering high up. I suggest you go down the scrappy and search for Citroen Xm's as finding that bottom mount is rather rare, or you could do what i think jonnie does and cut down the original 6 Mount, but that weigh's a ton but id say thats a last resort If anyone has a citroens parts cd, i'll have a look and try make it clearer, and have a look through my brothers S16 pics in my sig Alastair Edited August 4, 2007 by Alastairh Share this post Link to post Share on other sites
ChrisG 0 Posted August 4, 2007 Are the mi16 and 8v bottom mounts different? I have the 16v engine to put in, but no mount so will need to source one if they are different! Share this post Link to post Share on other sites
welshpug 1,678 Posted August 4, 2007 All XU rear mounts are identical, all bushes are interchangeable but there are some differences in the bush composition. XU10 top mounts are all the same IIRC too (i.e the bit that bolts to the block is anyway) Share this post Link to post Share on other sites
Spiky 37 Posted August 4, 2007 Are the mi16 and 8v bottom mounts different? I have the 16v engine to put in, but no mount so will need to source one if they are different! i have one here i cant use, 25 delivered and it's yours as that what i just paid for it, but you'll still need the bridge section Share this post Link to post Share on other sites
Spiky 37 Posted August 4, 2007 Right. As Martain said in one of your threads putting a S16 mount and 1.9 alloy mount side by side they're is bugger all in it for weight, so people can leave the sean type comments But what i run is (and have done for my brothers old S16) S16 top mount with the arm which also can be had off certain 2.0 8v 306's etc, then you need a Xm alternator mount and alternator from the models that run the second belt and have the power steering high up. I suggest you go down the scrappy and search for Citroen Xm's as finding that bottom mount is rather rare, or you could do what i think jonnie does and cut down the original 6 Mount, but that weigh's a ton but id say thats a last resort If anyone has a citroens parts cd, i'll have a look and try make it clearer, and have a look through my brothers S16 pics in my sig Alastair whether the s16 or 1.9 alloy weith the same or not, the 1.9 alloy will never fit, so why thats brough into the equation i have no idea. the top bridge section might the same as the xm turbo, the bottom section is far from the same. how jonnie makes the gti-6 std mount fit, but lower, i have no idea as i dont see how you can do it, AT ALL. so back to plan A and use the gti-6 mount and not bother to lower the engine, and my maybe just extended the lower rear mount. i really could not careless of saving weight, especially 1 gram or any thing, so i dont care which mount, i just want the right mount Share this post Link to post Share on other sites
welshpug 1,678 Posted August 4, 2007 whether the s16 or 1.9 alloy weith the same or not, the 1.9 alloy will never fit, so why thats brough into the equation i have no idea. the top bridge section might the same as the xm turbo, the bottom section is far from the same. yes but does it fit??? Share this post Link to post Share on other sites
ChrisG 0 Posted August 5, 2007 i have one here i cant use, 25 delivered and it's yours as that what i just paid for it, but you'll still need the bridge section Cheers but if they are all the same I don't need one, thanks anyhoo Share this post Link to post Share on other sites
Spiky 37 Posted August 5, 2007 Cheers but if they are all the same I don't need one, thanks anyhoo i think you mis under stood, the 1.9 8v and mi16 are different, and the gti-6 is different again i have a spare mi16 mount that bolts on the engine, again here if you need it Share this post Link to post Share on other sites
