Guest LLL Posted July 17, 2007 Hi, I've just been trying to replace the rusty old driving lights on my recently purchased GTi (loving it by the way ) and I don't seem to be able to remove the old lights. The nut and thread underneith the lights behind the bumper are rusted to hell on both sides. One side I can't move at all and I feel like if I tried any harder i'm going to damage the bumper! I'll attack that one with sdome anti-cease spray tomorrow - unless there are any other sugestions? The other light however is currenty more of a problem - when trying to undo the nut, the whole nut and threaded bar turns. Theres no access to the top of the threaded bar to clamp it and stop it from turning while trying to work the nut free so i'm a bit stuck and i'm admittedly fairly new to getting my hands dirty so i'm out of ideas!! I could probably grip the bottom of the threaded bar with some mole grips but I don't want to damage the threads because I want to replace the lights immediately. Any suggestions or tricks of the trade would be greatly appreciated. Cheers, Rob. Share this post Link to post Share on other sites
welshpug 1,629 Posted July 17, 2007 when I fitted new units I just used a nut splitter, but new lamps come with the bolts IIRC so it'll be fine to use an angle grinder (check first though...) make sure you get the right units from GSF, part number - T94912, no other supplier bar 205 parts and neat auto's seem to supply the right units. Share this post Link to post Share on other sites
matty_gti 20 Posted July 17, 2007 Simple answer......Angle grinder....sparks fly....old ones fall out.....you bolt in new ones...simple. Thats what i did:D Matt Share this post Link to post Share on other sites
Atari Boy 11 Posted July 17, 2007 Yes, angle grinder is the way. I got one at Argos cheaply enough. Share this post Link to post Share on other sites
DaveK 0 Posted July 17, 2007 Yep, i know the feeling mate, i was abit shocked at the size of the bloody bolts pug use to hold them on aswell That + rust = mr angle grinder Share this post Link to post Share on other sites
Guest LLL Posted July 17, 2007 Thanks for the advice people. What would be the best angle of attack with a grinder?? Share this post Link to post Share on other sites
welshpug 1,629 Posted July 17, 2007 remove the bumper, easy access then. Share this post Link to post Share on other sites
matty_gti 20 Posted July 17, 2007 Thanks for the advice people. What would be the best angle of attack with a grinder?? There is a metal bracket that bolts from the thread on the lamp to the body of the car to hold it all stiff, grind away just under this so basiaclly your gringing the nut away. Share this post Link to post Share on other sites
Atari Boy 11 Posted July 18, 2007 Exactly I was either lazy or stupid (or both) as I kept the bumper on, I lifted the car up at the front and went for it from underneath. Grind off the nut, it takes a little while as it is, as you say, weirdly oversized for the job. Remember to wear a long sleeved top though Share this post Link to post Share on other sites
matty_gti 20 Posted July 18, 2007 I swear i keep posting replys before welshpug Share this post Link to post Share on other sites
stutto 0 Posted July 18, 2007 I just drilled through the nut on one of mine. Share this post Link to post Share on other sites
