stutto
Sunroof Drains
stutto
I've done a search so I know where they run to but I partially dismantled the sunroof and could not see where they run from. Can someone tell me, I relaise it will probably seem obvious.
Thanks,
Chris.
GLPoomobile
As far as I'm aware there is a drain hole at either side. When you slide the sunroof back, look from above and in the channel there is a small hole at each front corner. It really should be quite obvious if it's there.
Unless of course you don't have a standard factory vacuum sunroof, and some aftermarket jobbie instead.
stutto
My sunroof has a fixed handle, I am pretty sure that there is no vacuum involved.
Does this mean that it is aftermarket? I had never really considered it before.
Paintguy
Does your sunroof slide back, or is it a pop-up one?
Any chance of a picture of it? Might help us to help you :(
trogboy
In my aftermarket sunroof the drains run into the rubber trim that covers the gap between the sunroof and the head lining!
When I get a little bit of crap under the glass which stops the seal from working properly it collects at least a pint before sloshing out when travelling round bends. I made the mistake of pulling the corner of the rubber trim down to check where the water was coming from - it looked like I'd pissed myself.
stutto
My sunroof is a slider, when it feels like it.
I'll try to get a photo tomorrow.
