Guest VesToft
Xu9ja Parts On Xu10j4
Guest VesToft
Will the starter and alternator from a xu9ja fit on a xu10j4?
yes :unsure:
Richie-Van-GTi
yes but yuou will need the correct tensioner bracket.
Guest VesToft
For the alternator right?
Other than that there won't be any problems....That sounds great. This means I will save some money, when I'm off to buy my new engine
yes
Guest VesToft
I guess that shouldn't be a to big of a problem to acquire.
Thank you for the help
Sort of, The pulley's are 1 tooth wider than the 8v's
28CRAIG
So make sure you use a 8v belt and i think they use a eye type connection instead of a spade so just need to crimp a new one on the sensor loom.
Guest VesToft
Ok. I'll tell it to my mechanic, then it's up to him, to make it work. Otherwise i'll just by a new alternator
