Guest dobbo
Diagnostic Port Location?
Guest dobbo
Seems I only come around these parts when I need help.. :guiltysmiley:
I have an intermittent fault which causes my engine diagnostic light to illuminate, so I bought one of those Draper fault code readers.
The instructions say to locate the green 2 pin diagnostic port on the inner wing/relay box/next to expansion tank. I found a 2 pin port on the inner wing but it's not green!?
Anyway, the diagnostic reader doesn't work here. So a bit more searching turned up a 2 pin green port over by the airbox:
Which looks like it should be the right one:
But this wone doesn't work either. So I guess my question is, am I looking in the right place? Mine's a late model K plate with a catalytic converter and (I believe) the later engine management system, hence the diagnostic light.
Can anyone help out a moron who doesn't know what he is doing? Thanks!
:P
pugpaul
Have you checked around the battery area? There should be a cream coloured plug hanging around there.....try that....hope it works!
Yes thats the one, There's not a diag port by the battery area, Good luck with getting any codes out!!
Andrwn8304
I bought one of them code reads a while after spending 2 weeks and a few trips to the dealers who couldnt find the Green Diag plug either, I emailed Draper to ask if it suitable for the Gti's and was told in polite manner because Draper doesnt make them for Gti's as they dont have a Diag Plug fitted to the engine.
Revla
Yours is probably pre cat so it won't. The later models (late K reg 1.9 on) will I believe.......
simonb
I think it's only the Motronic fitted cares that have them fitted. Earlier ones don't and so you are wasting your time.
Guest dobbo
Since mine's one of the last GTIs I assumed it would have one, certainly I thought mine was motronic.
Post your ecu number up & we'll soon let you know if your car is a motronic one or not.
IIRC the Motronic 205's have a black plastic inlet manifold though but yours might have been swapped for an alloy one by a previous owner for some reason.
Graham.
