rapidmi
2.0l Turbo Revcounter
rapidmi
what do i need to make the rev counter work, can someone pm me a copy of what i need to do electrically
cheers
des
Edited by rapidmi
JR20516V
cheers
des
Normally i think they are run from your coil however if you have an aftermarkrt ECU to run your turbo setup then you will need to run it from there correctly...if you have enuff outputs
rapidmi
i was under the impression that u had to make something up with a resistors and diodes
