matt350cos 0 Posted June 14, 2007 When I start my mi16 up it rattles a bit until the engine gets up to temp then the rattles goes away is this normal for a mi16 engine ? Share this post Link to post Share on other sites
Richie-Van-GTi 82 2 Cars Posted June 14, 2007 what oil are you using? Share this post Link to post Share on other sites
Mikey G 3 Posted June 14, 2007 I have heard a lot of Mi's with a lifter rattle, it is a fairly common problem. Try a different oil as a slightly thinner cold oil may work better, if your using 10w-40 trying going down to 5w-40. Share this post Link to post Share on other sites
Simes 248 2 Cars Posted June 14, 2007 What oil filter do you have. If it has no non-return valve then that could also explain it. Share this post Link to post Share on other sites
matt350cos 0 Posted June 14, 2007 I am using a 15/40 castrol oil i guess this would not be right then As for the oil filter just one i got from euro car parts Share this post Link to post Share on other sites
Arahan 4 Posted June 15, 2007 A mate of mine had the same thing on his CRX, turned out his exhaust manifold was the culprit, as it was not quite as tight as it should be! When the car was warm however it wouldn't make the noise! However this is a B16A and not an Mi16! Share this post Link to post Share on other sites
matt350cos 0 Posted June 16, 2007 I think i should try a 10/40 oil then Share this post Link to post Share on other sites
