andymi16
Buying A New Tps
andymi16
I think the tps is dead on my 1.6 gti.
Where can you buy a new one from?
Any know how much it will set me back?
matty_gti
Peugeot (not sure on prices) or you could allways get a good second hand one?.
Matt
ashlee205gti
There are ways of testing the TPS with a multimeter before you hand over any money.
matty_gti
Taken from a topic i started a little while ago. Quote from damirGTI
"Slacken the two throttle screws
Turn the switch fully clockwise, then go slowly back until you hear it "clicks" stop on that position and tight the screws .
Pull the connector out and connect the multimeter (set scale for "ohm" mesurment..) between terminals 2 and 18 in the switch , the multimeter should read zero ohms (throttle closed) , then fully open the throttle and multimeter should read infinity .
Connect the multimeter to terminals 3 and 18 the readings must be infinity (throttle closed), fully open the throttle and readings must be zero ohms .
If the readings are not correct readjust the switch position as above .
(note that you have three terminals in throtte switch 3 18 2)
hope this helps
Damir"
Matt
andymi16
Thanks a lot. I will deinatly give this ago.
At the moment i'm getting a really annoying 'on and off' acceleration around 1.8k - 2.5k revs.
I'll test her out this week...
Cheers again.
