grandos
Sad
grandos
Just to thank all the people that have put information on the SAD on this site as I have cleaned it up and set the the unit up so that it takes a little longer to close as per all the topics I've read and now my car runs nicely from cold to warm :(
The SAD has the engine running slightly fast 1100-1300rpm before slowing to 900-950rpm, just to check is this what should happen as I've never had a 205GTI running quite right from cold.
I've set the CO and now all I need to do is get around to checking the valves clearances cause they sound a little noisy. Is it worth changing the cambelt at the same time, don't think it was done all that long ago but will check!
Regards
Ben
