Baz 421 Posted May 17, 2007 (edited) As title really, i know the beam tube could be handy, what about the hubs, brakes, suspension etc? Are the wishbones, driveshafts etc as a GTi? What ratios would the 'box have? Many thanks in advance! Edited May 17, 2007 by BazGTMi Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 17, 2007 Basic 309 GRD will have base model suspension (springs, shocks, wishbones, arb etc), solid discs iirc but the hubs should be the same as 1.9 GTi ones. Gearbox should be same as a 205 diesel one.(3.47 fd). Not much really imo, beam tube is about all. Graham. Share this post Link to post Share on other sites
Turbo7379 3 Posted May 18, 2007 Front hubs & shafts are the same as 309 GTI . If it has PAS the steering rack could be useful for a quick rack conversion . Also keep the shaft that joins the rack to the steering column as the uj on it can often fail & it's useful to keep for a spare . Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 18, 2007 What about the rad? Diesel 205 rad is the same as GTi so I suspect the Diesel one may be as well. Also alternator, starter, rad fans, interior fan, headlights, indicators, rear hatch struts, etc. When you start scraping you'd be amazed how much stuff really is common (lock set,...) I'm slowly (very slowly) scraping a 205 GLD at the moment. Oh the seat mouts are handy if its a 5 door. They lower the driver's seat, you loose the tipping mechanism but I never used it on the driver's side anyway. Rob Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 18, 2007 Rad, headlights & indicators on a 309 are all different to the 205 ones. Strangely the 309 has a thinner rad than the equivilent 205 in most cases afaik. Definately on the SR/XS/GTi. Graham. Share this post Link to post Share on other sites
welshpug 1,723 Posted May 18, 2007 Hi BAZ, you don't happen to have a complete set of locks and keys for the car do you? They ARE different to 205 items (the door locks have a plastic shroud and the boot lock is very different but the ignition is the same) if its a 3 door I'm pretty sure the side doors will fit a 3 door 205!! (cant remember who told me that...) Share this post Link to post Share on other sites
Baz 421 Posted May 18, 2007 I still have the nearly new rad from the Goodwood i broke thinking i could make use of! They're wider than the 205 ones. De-PAS'd rack would be good too, cheers! Thanks all. Share this post Link to post Share on other sites
Baz 421 Posted May 18, 2007 One more question, is the beam the same as a GTi model, apart from the bar sizes? What sizes of TB's and Arb would it have does anyone know? Thanks again. Share this post Link to post Share on other sites
Baz 421 Posted May 18, 2007 Hi BAZ, you don't happen to have a complete set of locks and keys for the car do you? They ARE different to 205 items (the door locks have a plastic shroud and the boot lock is very different but the ignition is the same) if its a 3 door I'm pretty sure the side doors will fit a 3 door 205!! (cant remember who told me that...) Sorry, must've missed that the other day. It's a 5dr, but i can't remember if it has complete set of locks with a working key, i'll be pulling it apart over the weekend though, so will check and let you know. I remember the they are different, i had to buy a set for my first 309Gti, thought the spare 205 ones would fit at first but no, so turned into a fortune! I'll post back in here when i know. Share this post Link to post Share on other sites
Alastairh 47 Posted May 19, 2007 The Grdt turbo i came across had 19mm torsion bars, so not exactly sort after. Strip the beam, and weigh the rest in Share this post Link to post Share on other sites
