lyncho23 3 Posted May 16, 2007 hi quick question. can anyone tell me where the timing marks are on a 1.9, im doing the headgasket on my car and was going to ask my mate to fit the cam and time it all up for me, but hes going on holiday and doesnt really have time so i thought i might aswell have a go myself but just dont have a clue where to start. any replies greatley appreciated. thanks daz Share this post Link to post Share on other sites
Richie-Van-GTi 81 2 Cars Posted May 16, 2007 hole in the crank pulley and hole in the camshaft pulley. note the bottom end goes round twice to every full turn of the camshaft so if one lines up and the other is 180 degrees out just do a full rotation of the bottom pulley. Share this post Link to post Share on other sites
jas-E 1 Posted May 16, 2007 line the holes in the crank pulley and cam pulley and stick on the new belt. The new belt should have two lines painted on it. If you look carefully at the cam sprocket there shud be a notch on it near the edge. Line up one of the lines on the belt with that notch, and the second line (which has a triangle next to it) should line up with the notch on the crank sprocket. Sort that side of the belt and just continue fitting the water pump and tensioner. I did it for the first time this weekend gone..not as difficult as it seems!! Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 16, 2007 line the holes in the crank pulley and cam pulley and stick on the new belt. The new belt should have two lines painted on it. If you look carefully at the cam sprocket there shud be a notch on it near the edge. Line up one of the lines on the belt with that notch, and the second line (which has a triangle next to it) should line up with the notch on the crank sprocket. Sort that side of the belt and just continue fitting the water pump and tensioner. I did it for the first time this weekend gone..not as difficult as it seems!! Just to note that not all belts have these marks on them, Pug ones certainly do but not all 3rd party ones do. Share this post Link to post Share on other sites
lyncho23 3 Posted May 16, 2007 thanks for all the replies, ive just gone out to the garage and had a look at the belt and the marks are on there, i also found the marks on the cam sproket and crank sproket. just another quick question, is there any certain order you need to put the cam back on the head? for example is there a sequence like there is when you torque up the head bolts? thanks again guys daz Share this post Link to post Share on other sites
DamirGTI 362 Posted May 16, 2007 (edited) Hi ! Oil camshaft and caps prior to refitting (also it must be really well cleaned same as bearing caps inner surface - with no dust , hares or any type of dirt ..), start from the bolts in the middle and then go around like when tighting head bolts - same seqence troque settings : camshaft bearings caps - 15Nm rocker cover - 10Nm have fun ! Damir Edited May 16, 2007 by DamirGTI Share this post Link to post Share on other sites
lyncho23 3 Posted May 16, 2007 thats great thanks. does the cam shaft need to be in a certain position? daz Share this post Link to post Share on other sites
steve@cornwall 100 Posted May 16, 2007 thats great thanks. does the cam shaft need to be in a certain position? daz that will sort itself out, the cam has a woodruff key which has to fit into the pulley- there's your positioning Share this post Link to post Share on other sites
DamirGTI 362 Posted May 16, 2007 no , just oli the cam - caps and fit inside ... camshaft endfloat is not adjustable on these engines you will see how thigs works when you refit first bearing cap on flywheel side .. , and do not mix bearing caps they are numbered - No 1 at flywheel side and No 4 at timming belt side cheers Damir Share this post Link to post Share on other sites
