pugbliss 0 Posted May 14, 2007 hi all noticed this on the way home from work this morning performance onthe motorway is down, as im having to push furthher down on the pedle to get any decent go out of it (1.6gti) and when i got home i listerned to the exhaust and it sounded odd not like it usually does. usually there is a steady rumble and decent back presure but now the back pressure doesnt seem so strong and its phut phutting more. i must point out that it is despareate need of a full serevice and ignotion overhaull (totally skint till next month) but can this be just the reason why???? or is there something else up with it. oh i must also say the exhust is only aprox 5 months old and is of pattern quality from central tyres. any help apriciated Share this post Link to post Share on other sites
welshpug 1,722 Posted May 14, 2007 blown/collapsed baffles in the exhaust, give the boxes a tap and if they rattle then they are shot. Share this post Link to post Share on other sites
pugbliss 0 Posted May 15, 2007 Manifold is good no cracks at all. im wondering if i need a new coil or plugs as it seems to have got a bit worse, my new probs are it sort or stutters above 60 mph. itll have full power then it is as iff it sort of cuts the spark for a beat then comes back on. bit hard to explain properly what shall i start with..... pugs and leads or jump in the deep end and do coil and ignotion module first. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 16, 2007 Do check the exhaust, the first section should have a split but this can rust and bend partially blocking it. You just need to seperate the first section from the manifold and take a peek inside, you will soon see if it is blocked or not. Rob Share this post Link to post Share on other sites
pugbliss 0 Posted May 17, 2007 can this centre split rust so much in 5 months that it splits????? Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 17, 2007 Ah - not likely (must read posts more carefully!) but it may well lack the split altogether (some pattern parts just us a big single tune instead of a pair of D shaped ones welded back to back). This won't help the power but doubt it is your problem. Rob Share this post Link to post Share on other sites
steve@cornwall 100 Posted May 17, 2007 Ah - not likely (must read posts more carefully!) but it may well lack the split altogether (some pattern parts just us a big single tune instead of a pair of D shaped ones welded back to back). This won't help the power but doubt it is your problem. Rob They seem to almost melt, very quickly, if you're ignition timings not right........so still worth a check Share this post Link to post Share on other sites
Martin@PRD 0 Posted May 18, 2007 Has your mate stuffed a sock or a bannana in your tail pipe? Share this post Link to post Share on other sites
DaveW 6 Posted May 18, 2007 Try a different coil sounds like its on its way out.. Share this post Link to post Share on other sites
pugbliss 0 Posted May 19, 2007 no sock stuffed up there!!!! so should i do the coil first or ignition amp first???? im gonna do plug and leads as a matter of course cos they aint been done for 2 yrs plus. and dizzy cap and rota look ok for now. Share this post Link to post Share on other sites
