paul_portsmouth
Brake Lights
paul_portsmouth
my brake lights have decided to stop working
i have side lights but no break lights
is there a common fault here?
g60-r
bulbs, fuses............
check the brake pedal switch and the wires are connected as they can fall off, It's easy to see with the glove box part off under the steering coloum
paul_portsmouth
thats what i was told will have a look later when the football is cleared and i can bring the car home
( only parking on one side when its on :@
Mikey S
as miles says they sometimes fall off. if it hasnt, bridge the terminals on the connector together with ign on. this will bring the stop lights on indicating that the switch is dead.
if it doesnt look at the bulbs and check that you have a supply to the brakelights themselves. :P
paul_portsmouth
the switch was loose and wound itself in too far so wasnt switching when the pedal was pressed :S
paul_portsmouth
turns out it wasnt the switch at all one of the connectors had a dodgy connection all fixed now though
