djinuk 2 Posted May 11, 2007 Ok i want to adjust the timing on the dizzy on my F reg 205 xs. where abouts do i aim the strobe ?, the pulley? , and where are the markers to adjust it between. Only car i have ever done this on was a mini. Let me know cheers Share this post Link to post Share on other sites
Jrod 7 Posted May 11, 2007 You aim it at the fly wheel, to adjust you turn the dizzy I think its 8 degrees BTC but don't quote me. Share this post Link to post Share on other sites
sutol 0 Posted May 11, 2007 Should be a marker on the flywheel somewhere, have a look in haynes Or you can find TDC on No1 and mark the pulley yourself (prob more accurate) Share this post Link to post Share on other sites
RossD 43 Posted May 12, 2007 Should be a marker on the flywheel somewhere, have a look in haynesOr you can find TDC on No1 and mark the pulley yourself (prob more accurate) Yep, make sure the strobe light is connected to the right cylinder. The place to aim is between the engine block and gearbox bell housing at the front, usually covered by a plastic plug. I usually find it easier to put tippex on the correct marks, shows up really well under the strobe. Share this post Link to post Share on other sites
djinuk 2 Posted May 18, 2007 which ht lead should i connect the strobe onto ? Share this post Link to post Share on other sites
RossD 43 Posted May 18, 2007 which ht lead should i connect the strobe onto ? Usually 1 or 4 Share this post Link to post Share on other sites
djinuk 2 Posted June 3, 2007 ok ive had a go, i took the flywheel cover off, but what rpm do i set the stobe to , and also what is BTC? Share this post Link to post Share on other sites
Jrod 7 Posted June 3, 2007 Before top dead centre (sorry I missed out the D) Share this post Link to post Share on other sites
djinuk 2 Posted June 4, 2007 hmm,, sounds complicated Share this post Link to post Share on other sites
RossD 43 Posted June 4, 2007 hmm,, sounds complicated Not at all. The Haynes covers it too. Share this post Link to post Share on other sites
djinuk 2 Posted June 4, 2007 going to have a read tonight, my haynes manual seems really bad with the tu engine, Share this post Link to post Share on other sites
