Blish10
Uneven Front Suspension
Blish10
Hi guys. I've just got my car back on the road after having an engine rebuild, but after a bit of a clean, I noticed that the gap between front wheel arches and wheels is bigger on O/S than on N/S. Got out the old verniers and it was almost 2cm difference?! Any ideas why and how do I go about sorting it? Any help greatly appreciated
brianthemagical
check the struts are i9n the hubs proper like and everthing else is correct.did you torgue the wishbone bolts with the car on the ground, if not then do so. failing that either something is bent or parts were mis-matched at some point in it's life.
Blish10
Nice 1. Cheers chap. The strut wasnt quite seated properly
