mikey_p 0 Posted May 5, 2007 My washer jets appear to be leaking from the seal that joins it to the bonnet, and I now have water stains all over my bonnet which is a bitch to wash off for some reason. The only time I have seen them leaking is when I was parking and was not giving the car to many revs and water was bubbling from the seal, it is probably completely un-related but that is the only time i've seen it happen. They work without a problem, but it's really annoying that my bonnet is now stained. Has anyone else had this problem, is there some solution or is it just a case of replacing them or the tubes? Cheers Mike Share this post Link to post Share on other sites
205johnnyxsi 0 Posted May 8, 2007 is it leaking from the two or just the one? Share this post Link to post Share on other sites
reg 0 Posted May 8, 2007 Screenwash isn't great for paint work, but i wouldn't of thought it would stain unless its been like that for a very long time. I would just pick up some washer jets from a scrap yard, any 205 should do. But first open the bonnect and have a a closer look at the seals while you get a mate to use the washers. Share this post Link to post Share on other sites
