Mad Professor
Minimal Valve Clearances
Mad Professor
The good old joke book states the following.
Valve Clearances (Engine Cold)
Inlet: 0.15 - 0.25mm
Exhaust:: 0.35 - 0.45mm
I would like to know what is the minimal safe Valve Clearances you can use on the 205 8v engine.
At this point in time I am using.
Inlet: 0.15mm
Exhaust:: 0.30mm
I know there was a post quite some time about this, But I am unable to find it at this time.
Thanks For Your Time.
Best Regards.
Ahl
Pumaracing says:
0.20-0.25mm on the inlets and 0.30-0.35mm on the exhausts btw. The Pug spec on the exhaust is unnecessarily large IMO and engines run quieter and smoother with my own settings.
Hope that helps. :(
