e30m3 0 Posted April 23, 2007 I've managed to get my car running ok other than having very high idle, the screw on the throttle body is all the way in. What could cause this. If you tap the accelerator ithe revs drop down but then pick back up. Share this post Link to post Share on other sites
Richie-Van-GTi 82 2 Cars Posted April 23, 2007 try adjustying the throttle stop screw, it may be holding the throttle part open, assume that youve checked the throttle cable isnt holding it open? Other than that ignition too far advanced or an air leak. Share this post Link to post Share on other sites
e30m3 0 Posted April 23, 2007 Thanks for the reply I don't think theres a problem with the cable but you've given me a few things to check Its going for its MOT on Wednesday, they can look at it but i'd rather sort it out myself first. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 23, 2007 Have you tried squeezing the hose from the SAD to see if it drops down again? Graham. Share this post Link to post Share on other sites
205johnnyxsi 0 Posted May 6, 2007 hello i had sort of the same sort of problem on my xsi 309 which is the same engine as the1.6 gti, i tuk my air box of and see if stalled , which it didnt which ment i had a air leak, i used some leak spray of a plumer i no that found where my leak was, got that sorted then it came to trying to get the idle down, theres a brass/copper screw on the top of the throttle body just play with that till you are happy, hope thats any help Share this post Link to post Share on other sites
brianthemagical 1 Posted May 6, 2007 (edited) what do you class as a high idle? i had the same problem, can't remember what cured it though, it wasn't an air leak or anything like that, may have been ignition timing. Edited May 6, 2007 by brianthemagical Share this post Link to post Share on other sites
